Hi!
I’m running Openhab2 with tellstick plugin successfully since a few month. My API-keys are working well.
Now, im trying to install HA since the support for Tellstick seems to be much better. I have followed the guidelines for inserting the keys and tokes in the config file, i have checked for white spaces etc…
The keys i received are the same as for OH2, but in the logfiles it says :
[tellduslive] Failed request: 401 Client Error: Unauthorized for url: https://api.telldus.com/json/user/profile
Any clue on what a HA noob should try to get it to work?
Or does telldus have some limit so i couldnt use the keys from 2 separate software (that knocking on their door)
Having the same issue, worked fine with a manual installation of HA, then I decided to try out a new fresh Hassbian installation. Are there any changes with the handling of telldus live configs?
There are two components, one for Tellstick and one for Telldus live. Are you sure you’re using the right one? This is what I’m using with Telldus live: https://home-assistant.io/components/tellduslive/
Seems like you are though. Do you want to share your config file? I’ve got a working one I can compare it to.
