I´m havin problems with my temperatur meters in home assistant. I have puchased 3 telldus temperature and hydrometers and i keep geting the wrong temperature in home assitant. I have other sensors that give the right numbers butt telldus wont. This is the code i get, the temperature shovs as -13,8 but it is really +22. its the same with all the sensors so i can rule out that theres something wrong with the sensor. any sugestions?
I contacted the support and it´s a problem with Alecto devices using the same pulse as tellstick but coding temperature in a different way. The guys where wery helpful and provided me with a solution
I contacted the guys who made the Rflink and they sent me an new firmware witch i then installed and used a command on to make it code it as tellstick.
I tried to contact RFLink but did not receive any response to my emails. While still waiting for the new RFLink firmawre that will fix this, I have implemented the following workaround in config file. In my case the difference is 39.5. degrees, so I just created a new sensor that corrects the value by adding 39.5 using a value template. At the same time I rename the sensor from .alectov3_30c7_temp to Telldus_1. Unfortunately, occasionally the correct values seem to get through and that messes up my graphs. For this reason there is extra test to determine whether I need to correct (value below 5 degrees) or not (value above 5 degrees). I am also filtering some outliers that seem to occasionally strike through and finally I use the Average sensor custom component to smoothen the values for less noisy graphs (you can do this using statistics integration as well).
I have three different Telldus sensors and the correction value is a bit different for each of them and therefore I have adjusted the correction term manually.
I too am seeing this problem with some sensors I recently acquired. I am trying your template solution @HEMARIS , which seems to work, but it would be great to get an actually fixed firmware.
Looking at the latest change log entry (6-1-2022), it seems that the fix is at least in some kind of WIP firmware:
Still no one that has access to the fixed firmware?
