Telldus thermo/hygro sensor 313160 issues?
I bought a new sensor from telldus, 433 Mhz and all. It only has 8 channels to choose from. No matter what channel I select it won’t show up in Home Assistant.
I have other sensors on the Tellstick (Duo) that’s being read fine.
Any ideas what could be the issue?
Are you using Telldus, RFXCOM or something else to receive/send the 433 MHz frequency ?
I’m running a Tellstick Duo and just the standard tellstick add-on
OK, then I’m unable to assist :confused: I have converted from Telldus to a RFXCOM.
