I’m quite certain this is the cause. I’ve removed my images and republished them and it seems that the amd64 had overridden the aarch64 one now, so it should work fine for amd64.
Thank you very much for your efforts. Has anything changed in the fork over the last two days? If not, the current status is that it does not yet work with amd64. Or have I misunderstood something?
Thank you very much. Quick question for everyone: since this evening, I am no longer receiving notifications from Home Assistant that the add-on has been removed from the repository. Until now, confirming this notification meant that the add-on was removed. Am I the only one who has noticed this?
HA Core 2025.12.4
EDIT: The Message is back, i am going to retry this repo and let you know the outcome asap.
I am happy to report that everything is working fine. The service can be started and the devices can be controlled. @michaelarnauts Thank you very much for helping us out!!!
Correct, as indicated above, I have uploaded the amd64 version. I don’t know how to get both the amd64 and aarch64 version on dockerhub and not overwrite the other file.
hello newbie here. I have tellstick I have loads of units in use for years and worried I may loose it all, (its why I started using HA). I am not dumb but ignorant! How do I use this addon to save my tellstick. Please point me in the right direction, many thanks.
