@Henrik1986 thank you. Read it and seems straight forward. One question though: the device is set up in the tellstick.conf file. So for instance id = 1 is “name = sensor1”. How do i then “synchronize” that sensor which I’ve given id=1 with the stick?
thank you.
Good day, following this guide https://www.automatiserar.se/guide-raspberry-pi/ and cant download the repository. getting this error on the RPI3 after sudo apt-get update
Reading package lists… Done
W: GPG error: http://download.telldus.com/debian stable Release: The following signatures were invalid: 70C410C9D73D53E838B31C585A949181E501EA76
W: The repository ‘http://download.telldus.com/debian stable Release’ is not signed.
N: Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Any suggestions welcome.
Thank you
There is no signed version of Tellstick in newer version of raspian. Are you using stretch?
I think i run a raspian Jessie version. You can download older raspian version here Index of /raspbian/images
And if you run your HASS on a virtual enviroment the Python version can be upgrade. 3.6 version i minimum from next year.
Follow this guide till upgrade Python version in a VE.
Henrik, thank you. I am using stretch. I followed this tutorial:
and it’s working
So now trying to add first sensor. So just did this in the conf file
device {
id = 1
name = “Master Balcony Door”
protocol = “arctech”
model = “codeswitch”
parameters {
house = “A”
unit = “1”
now, how do I “connect” the sensor to the stick?
Ok, after doing it the hard way i’ve got it installed, added a sensor and “learned” it.
Problem now is it doesn’t show in HA.
I can see it as a switch, but it doesnt turn on or off.
All I added was
- platform: tellstick
Do i need to add more?
Try to add
tellstick:
In your configuration.yaml
Then restart
