Hi
A general question about installation. I want to use Tellstick with Home Assistant on my Raspberry Pi. I have already installed Home Assistant.
Should I then install Telldus drivers and also configure devices in telldus.conf?
Enabled Tellstick in configuration.yaml with:
switch:
platform: tellstick
@Svartbacken You are correct. Got nothing to add really.
A quick tip that I forget way to often. Don’t forget to restart the telldus deamon after updating the telldus.conf file to have the changes reflected in the tdtool or HA
Has anybody created a install script for the Telldus Tellstick on Raspberry Pi ?
Simular to the “Raspberry Pi All-In-One Installer”.
I will also be setting up Tellstic Duo with my Home Assistant.
Hi, have struggled with z wave sensors and I’m thinking of getting a tellstick and some sensors.
Can anyone prsome feedback on the product and what’s the average distance range. Thank you
@Henrik1986 thank you very much. I’ve ordered it
I may need some installation guidance when it arrives. Can you recommend a link. The OEM’s site is in Swedish…
