The switch itself works, but I would like to assign a unique id so I can assign the switch to an area, however it seems this platform doesn’t allow unique_id (the documentation doesn’t list it as an option and with it inserted in my configuration.yaml it fails config check). Is there some way to set this up differently such that I can give it a unique id? Thanks
Just so nobody else wastes their time … Out of curiosity I copied this entity and set “unique_id” through “customize.yaml”, but alas although it looks ok in Dev Tools, it does not trick the system into allowing the area to be set.
Hi, are there any work arounds I could employ you are aware of like creating some other entity type that fires of this one or maybe some automation type affair but where I have a switch for the front end.
I had trouble with the value_template in the telnet switch. I validated in nodered with tcp request node that ‘get ledprofilevideo\n’ returned ‘ledprofilevideo 1\n’ but it simply refuses to evaluate as true. I assume its something to do with how the carriage return is being treated, maybe to evaluate equivalence in template \n is not the correct term (I tried \r\n, \n but neither works). So in the end I resorted to the above.
