jeeftor
(Jeef)
1
I’m w wondering about auto C->F temp conversion. I added a Aquara temp sensor and I’m showing it in two different cards.
In one card (left) its converting into F whereas on the other card (history) its coming across as C.
I’m happy to write a patch for the history card - if somebody can point me to where I need to look for that.
I renamed it AQUARA on the left card - its LUMI xxxx on the right.
Thanks!
koying
(Chris B)
2
The label, you mean?
Because the data seems consistently °F
jeeftor
(Jeef)
3
I mean why is it on a separate graph. It’s a f value listed as c
koying
(Chris B)
4
Seems like a DB issue
Likely, the issue will disappear when the values with wrong unit will be purged.
jeeftor
(Jeef)
5
I ended up purging the 1st entry (in c) from the sqlite db and it all worked out
