Temp, Humidity sensor
hi what’s is a good accurate temperature and humidity sensor for zha, doesn’t need a screen
Anyone help?
Sonoff SNZB-02P is a good sensor
Thank you, I take it doesn’t need anything extra like a hub, I already have a sonoff zigbee co-ordinator with a few inner plugs and a couple of aqara devices all connected via zigbee
Hi @paulgryan52 ,
I like to create the sensors myself.
Buy a cheap D1mini and a sensor (DHT11, DHT22, BME280, DS18b20 or whatever you like). Most of the sensors are more then good enough for most use cases.
With a little bit of soldering and ESPhome, you have it running in no time. :slight_smile:
I can’t due to disability, just need something pre-made
I’ve had good luck with the Aqara ones. Amazon.com: Aqara Temperature and Humidity Sensor, Requires AQARA HUB and Not Support Third Party Hubs, Zigbee, for Remote Monitoring and Home Automation, Compatible with Apple HomeKit, Alexa, Works with IFTTT : Tools & Home Improvement
thanks so it’s between aqara and sonoff
