Hello!
I’m looking for help troubleshooting an issue that cropped up over the last few months. I have two zigbee temp/humidity sensors that I have mounted in my home. At first, everything worked great but after some update, the humidity value has been “unknown”. I’m only pretty sure this happened after I did an upgrade and I’m unsure to what version. I recently recovered from a corrupted SD card and I’m currently running version 0.95.4. The sensors are showing up as “CentraLite 3310-G”
The current states:
I’m not seeing anything in the logs that would explain what is going on. Any help would be appreciated.
