Temperamental ZHA
My ZHA integration works, sometimes. I am trying to run my Zigbee network on my Synology NAS with HA in a docker container and a Nortek stick. The zwave portion functions flawlessly. I am trying to use an Ikea Tradfri 5 button remote and two innr outlets.
I have had everything working a few times but when I restart HA I get the below error. I have uninstalled and reinstalled the integration several times. Any help is appreciated.
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:152
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 3:12:27 PM (4 occurrences)
Last logged: 3:13:20 PM
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator
  File "/usr/local/lib/python3.9/asyncio/tasks.py", line 492, in wait_for
    fut.result()
asyncio.exceptions.CancelledError
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 152, in async_initialize
    self.application_controller = await app_controller_cls.new(
  File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
    await app.startup(auto_form)
  File "/usr/local/lib/python3.9/site-packages/bellows/zigbee/application.py", line 124, in startup
    self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
  File "/usr/local/lib/python3.9/site-packages/bellows/ezsp/__init__.py", line 83, in initialize
    await ezsp.reset()
  File "/usr/local/lib/python3.9/site-packages/bellows/ezsp/__init__.py", line 98, in reset
    await self._gw.reset()
  File "/usr/local/lib/python3.9/site-packages/bellows/uart.py", line 223, in reset
    return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
  File "/usr/local/lib/python3.9/asyncio/tasks.py", line 494, in wait_for
    raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
I’m thinking it could be an issue with my Nortek stick. ZHA works interminably with no other changes other than a restart. I only have one Ikea remote and one innr plug connected currently. I cant add a second innr plug.
I am having exact same issue. I just setup ZHA for the first time.
@BVavra Any solution yet?
First occurred: 1:14:11 pm (6 occurrences)
Last logged: 1:17:09 pm
    fut.result()
    await ezsp.reset()
What version of DSM are you on and did you recently upgrade to DSM 7?
Synology dropped USB device support in DSM7 and it only works for certain sticks like the CC2531 at the moment, @BeardedConti did a Youtube video about this recently.
Issue is solved for me. I removed the integration, restarted HA, delete zigbee.db then add integration again and all is fine now.
I’m still having trouble with mine. I’m going to try your solution and change my wifi channel.
