This question is probbably dumb, but I’m quite new and don’t now much about automations.
I want to use as trigger or condition a certain value of the temperature of a water tank.
I can use the value of the temperature of the probe as trigger and condition, but the value can be changed during the year, so I’ll have to change the trigger or condition value in every automation.
Is there a way to set a variable (something like “tank temperature to start floor heating”) and relate the triggers and conditions to that variable wich in turn will be related to the value of the probe?
In this way, I only have to change the value in the variable and all the automations will be updated.
I hope I had explain myself propperly.
Thanks in advance.
You can put the number helper in the dashboard and then in your automations and scripts reference the number helper either via state of you want to use an exact value or via a numerical state if you want to use above and below or finally you can reference it in templates.
