I successfully paired sensor zigbee _TZE200_znbl8dj5
Device is listed as supported in ZHA here: Tuya Temperature and Humidity Sensor with LCD Display CX-7026 Zigbee compatibility
Device is sending data, but all values are zero:
Humiduty 0.0%
Temperature 0.0°C
Battery 0%
Other type of devices in this zigbee network works well.
Thanks for help.
Used coordinator for zigbee:
ESP32 Tasmota firmware with RAW TCP on socket with modem
EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis
Signature of sensor _TZE200_znbl8dj5
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0302",
"in_clusters": [
"0x0000",
"0x0001",
"0x0402",
"0x0405"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE200_znbl8dj5",
"model": "TS0601",
"class": "zigpy.device.Device"
Diagnostic data for sensor _TZE200_znbl8dj5
"home_assistant": {
"installation_type": "Home Assistant Container",
"version": "2022.9.7",
"dev": false,
"hassio": false,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "armv7l",
"timezone": "Europe/Prague",
"os_name": "Linux",
"os_version": "5.4.79-v7l+",
"run_as_root": true
"custom_components": {
"jablotron100": {
"version": "3.13.0",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.33.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.79",
"zigpy-deconz==0.18.1",
"zigpy==0.50.3",
"zigpy-xbee==0.15.0",
"zigpy-zigate==0.9.2",
"zigpy-znp==0.8.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 62750,
"model": "TS0601",
"name": "_TZE200_znbl8dj5 TS0601",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4417,
"power_source": "Battery or Unknown",
"lqi": 152,
"rssi": -62,
"last_seen": "2022-10-17T20:46:28",
"available": true,
"device_type": "EndDevice",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0001",
"0x0402",
"0x0405"
"out_clusters": [
"0x000a",
"0x0019"
"active_coordinator": false,
"entities": [
"entity_id": "sensor.teplota_obyvak_battery",
"entity_id": "sensor.teplota_obyvak_temperature",
"entity_id": "sensor.teplota_obyvak_humidity",
"neighbors": [],
"endpoint_names": [
"name": "TEMPERATURE_SENSOR"
"user_given_name": "Teplota obyv\u00e1k",
"device_reg_id": "670fdc037bff194b63396d5f4d0f953c",
"area_id": "obyvak",
"cluster_details": {
"1": {
"device_type": {
"name": "TEMPERATURE_SENSOR",
"id": 770
"profile_id": 260,
"in_clusters": {
"0x0001": {
"endpoint_attribute": "power",
"attributes": {
"0x0020": {
"attribute_name": "battery_voltage",
"value": 0
"0x0021": {
"attribute_name": "battery_percentage_remaining",
"value": 0
"unsupported_attributes": {
"0x0031": {
"attribute_name": "battery_size"
"0x0033": {
"attribute_name": "battery_quantity"
"0x0402": {
"endpoint_attribute": "temperature",
"attributes": {
"0x0000": {
"attribute_name": "measured_value",
"value": 0
"unsupported_attributes": {}
"0x0405": {
"endpoint_attribute": "humidity",
"attributes": {
"0x0000": {
"value": 0
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZE200_znbl8dj5"
"0x0005": {
"attribute_name": "model",
"value": "TS0601"
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
