Temperature and humidity sensor ZY-HS03
Hello.
I bought 4 pieces of temperature and humidity sensors. Under the tuya application they work without any trouble. I am currently migrating to HA and unfortunately Conbee II does not see them. Are you able to help me somehow?
On the box there is a marking ZY-HS03
Hi, I got 2 of these and I was able to add to HA via ZHA. But problem here is that its not showing temp or humidity. Only battery level :confused:
found a solution:
  1. If the temperature and humidity values are not showing, go to the device in HA and select Triple Dots → Manage zigbee device → select TuyaAirQualityHumidity in clusters → measured_value in attributes → read attribute. Repeat the same for the TuyaAirQualityTemperature cluster. Restart HA again. Verify in the device’s ‘Download diagnostics’ that the temperature and humidity are no longer unsupported values - you may need to refresh the page to see the sensors.
I’ve been trying to get the converter to work… but no luck. The closest one I could get connected was
No sensors, just label as Unsupported
Hello , same problem then proroug ,
Hint of you (joel204) is working, MANY THANKS… I was lost, and on the verge to send them back joel204 ,
SUPER
Just to confirm following the solution for joel2024 works. I did this for both the humidty and temperature attributes, restarted HA and they appeared as expected.
Hi
I checked this solution and it partially works.
Sensor values showed up, but they are not updating. Is there any way to set auto refresh or I need to make some automation to refresh this?
Ok, cancell that. It updated after 1h and then this is bit random, but updates are working :slight_smile:
I bought two of these but adding them to ZHA is not working properly. They appear as “unknown manufacturer” and provides only the temperature reading.
Did anyone manage to get these working in ZHA, recently?
My devices did not expose either TuyaAirQualityHumidity nor TuyaAirQualityTemperature in the cluster list.
The solution was to reload the ZHA integration (no need to restart Home Assistant). The clusters turned up and I could follow joel204’s advice (manually read the “measured_value” attribute for both sensors). Another ZHA reload and now it all works great.
Here’s the ZY-HS03 next to a Shelly H&T Gen 3:
Thank you @joel2024, your solution worked for me too, using modules labelled ZY-HS03 but detected in HA as TY0201.
