I have a snake terrarium and want to get hydro and temp sensors using zigbee preferably. I will be able to do zwave also if need. What does everyone use?
If it were me, I’d use an ESPHome device: Wemos D1 Mini with an SHTC3 temperature and humidity sensor.
Thank you for that. That may be a little more technical than I’m capable of ATM. Is there anything more RTU out of the box? I’m a total noob.
In that case, the following thread may be helpful:
Thanks for that. I do have zigbee set up to run with Hue lights. I’ll check out the thread. Thanks!
