mclever
(mclever)
June 4, 2022, 5:08am
1
2022.5 I used this template as trigger and it no longer works with 2022.6
{{ state_attr("climate.downstairs", "current_temperature") > 74 }}
It works in dev tools just fine, but doesn’t work as trigger.
Also tried this as trigger
platform: numeric_state
entity_id: climate.downstairs
attribute: current_temperature
above: '74'
Neither seem to work
tom_l
June 4, 2022, 5:49am
2
The temperature has to go from below 74 to above 74 to trigger. If it is already above 74 when you save/reload the automation, or if it changes state above 74 (e.g. 77 to 78), it won’t trigger.
mclever
(mclever)
June 4, 2022, 1:33pm
3
Yes it used to work like that now it doesn’t with latest upgrade.
Also have one for temp outside vs inside and notify that it’s time to open windows that doesn’t fire since 2022.6
mclever
(mclever)
June 4, 2022, 3:40pm
4
Played with it some more today and the numeric state works, but the template doesn’t work any more. Now to rework automations…
tom_l
June 5, 2022, 12:27am
5
Check that your climate entity attribute still exists and that it is reporting a number, because it works for me:
mclever
(mclever)
June 5, 2022, 12:41am
6
Works fine in dev tools but doesn’t trigger automations like they used to
tom_l
June 5, 2022, 1:15am
7
That’s not possible. Show your full automation.
mclever
(mclever)
June 5, 2022, 1:41am
8
Here is the adjusted one that’s working
alias: Family Room Fan Turn on when warm enough and TV is on
description: ''
- platform: numeric_state
above: '74'
condition:
- condition: state
entity_id: remote.family_room_tv
state: 'on'
- device_id: 07f58f2941334d04abb89e17adcd3041
domain: fan
entity_id: fan.family_room
type: turn_on
- service: fan.set_percentage
percentage: 100
Here is the one that used to work for telling me when to open the windows
alias: Notify - Time to open the windows broadcast
description: ''
- platform: state
entity_id: sensor.openweathermap_temperature
condition:
- condition: template
value_template: >-
{{ state_attr('weather.openweathermap', 'temperature') <=
state_attr('climate.upstairs', 'current_temperature') }}
- after: '15:00:00'
before: '21:00:00'
condition: time
- condition: and
conditions:
- type: is_not_open
condition: device
device_id: b3e1c3d3100711eb9a73b1e7b740c7d0
entity_id: binary_sensor.master_bedroom_window_sensor_left
domain: binary_sensor
- condition: or
conditions:
- type: is_not_open
condition: device
device_id: 4495b2117b1b084724f7b404939d51f9
entity_id: binary_sensor.master_bedroom_window_sensor_right
- condition: numeric_state
entity_id: sensor.aqi
attribute: level
below: '2'
value_template: '{{ state_attr(''climate.upstairs'', ''current_temperature'') > 70 }}'
value_template: '{{ state_attr(''weather.openweathermap'', ''temperature'') > 66 }}'
- service: tts.google_translate_say
entity_id: media_player.all_indoor_speakers
message: >-
It's time to open the windows. It's {{
state_attr('weather.openweathermap', 'temperature') | round(0) }}
degrees outside and {{ state_attr('climate.upstairs',
'current_temperature') }} inside.
- device_id: b82023aa92fd91c90941a126bc210e36
domain: cover
entity_id: cover.master_bedroom_large_windows_left_curtain
type: set_position
position: 100
- device_id: b136983557e931d8e3174e1554a4fc0a
domain: cover
entity_id: cover.master_bedroom_large_windows_right_curtain
type: set_position
position: 100
mode: single
tom_l
June 5, 2022, 2:04am
9
Well that’s completely different from the template you posted originally. It helps if you post the actual template you are using. Don’t simplify it. That just means people helping you aren’t working with the actual issue.
Are both of these attributes numbers with the same format?
value_template: >-
If not you may have to convert them to numbers before testing with the comparison:
value_template: >-
{{ state_attr('weather.openweathermap', 'temperature')|float(0) <=
state_attr('climate.upstairs', 'current_temperature')|float(0) }}
Also did you check your log for template errors?
