Temperature-based light color
Automatically change the color of one or more Home Assistant lights based on a temperature sensor.
Features
  • :thermometer: Use a temperature sensor to control one or more lights
  • :artist_palette: RGB color interpolation between configurable cold, normal, and hot colors
  • :light_bulb: Color-temperature interpolation between configurable Kelvin values
  • :thermometer: Configurable minimum, normal, and maximum temperatures
  • :stopwatch: Configurable light transition duration
  • :counterclockwise_arrows_button: Optional minimum temperature-change threshold to reduce unnecessary updates
  • :light_bulb: Option to update only lights that are already on
  • :bright_button: Automatically synchronizes a light when it is turned on
  • :rocket: Synchronizes eligible lights when Home Assistant starts
  • :shield: Ignores unavailable and unknown temperature sensor states
  • :chart_increasing: Temperatures outside the configured range use the corresponding endpoint color
The temperature range is divided into two phases:
Cold ─────────────► Normal ─────────────► Hot
The configured normal color is reached at the configured normal temperature.
Requirements
Temperature sensor
The selected sensor must:
  • Be a sensor entity
  • Have the temperature device class
  • Provide a numeric temperature state
  • Use Β°C, as the blueprint’s temperature thresholds are configured in Β°C
Lights
One or more light entities can be selected.
For RGB mode, the lights must support RGB color.
For Color temperature mode, the lights must support color temperature and a compatible Kelvin range.
The exact result can depend on the capabilities of the individual light or light integration.
Only update lights that are already on
This option is enabled by default.
When enabled, temperature changes only affect lights that are currently on. The blueprint will not turn an off light on.
When a configured light is subsequently turned on, its color is automatically synchronized with the current temperature.
If the option is disabled, the blueprint can also update lights that are currently off, which may turn them on.
Minimum temperature change
Use Minimum temperature change to prevent frequent small sensor fluctuations from causing unnecessary light updates.
For example, with a threshold of 0.5 Β°C, changes smaller than 0.5 Β°C are ignored.
Set it to 0 to process every temperature state change.
Temperature range
The configured temperatures must satisfy:
Minimum < Normal < Maximum
Temperatures below or above the configured range are clamped to the cold or hot color respectively.
For more detailed information about the interpolation, configuration options, and troubleshooting, see the project README.
Installation
Click the Import Blueprint button at the top of this post, or import the blueprint manually using:
https://raw.githubusercontent.com/tobus3000/hass-temperature-based-light-color-blueprint/refs/heads/main/blueprints/automation/tobus3000/temperature_based_light_colors.yaml
Alternatively:
  1. Go to Settings β†’ Automations & scenes β†’ Blueprints
  2. Select Import Blueprint
  3. Enter the raw GitHub URL
  4. Select Preview
  5. Import the blueprint
Full blueprint
blueprint:
  name: Temperature-based light color
  description: >
    Changes the color of one or more lights based on a configurable
    temperature sensor.
    The color changes through three configurable temperature points:
    cold, normal, and hot.
    The transition is split into two phases:
    cold β†’ normal and normal β†’ hot.
    For RGB mode, the colors are interpolated between the three
    configured RGB colors. This allows colors such as blue β†’ green β†’
    red, with the intermediate transition naturally passing through
    cyan, yellow, orange, and other intermediate colors.
    For color-temperature mode, the Kelvin value is interpolated
    through the same three temperature points.
    When "Only update lights that are already on" is enabled, the
    automation never turns an off light on. When a light is subsequently
    turned on, its color is synchronized with the current temperature.
    The configured color is also applied to eligible lights when
    Home Assistant starts.
  domain: automation
  author: tobus3000
  source_url: https://github.com/tobus3000/hass-temperature-based-light-color-blueprint
  homeassistant:
    min_version: "2024.10.0"
  input:
    temperature_sensor:
      description: >
        The temperature sensor whose value controls the light color.
        The sensor state must be expressed in Β°C.
      selector:
        entity:
          filter:
            - domain: sensor
              device_class: temperature
    target_lights:
      description: >
        One or more lights whose color should follow the temperature.
        The selected lights must support the selected color mode.
      selector:
        entity:
          multiple: true
          filter:
            - domain: light
    color_mode:
      description: >
        Choose between RGB color interpolation and color-temperature
        interpolation.
      default: rgb
      selector:
        select:
          options:
            - label: RGB color
              value: rgb
            - label: Color temperature
              value: color_temperature
    min_temperature:
      name: Minimum temperature
      description: >
        At or below this temperature, the cold color is used.
        Temperature thresholds are expressed in Β°C.
        Must be lower than the normal and maximum temperatures.
      default: 0
      selector:
        number:
          min: -50
          max: 100
          step: 0.5
          unit_of_measurement: "Β°C"
          mode: box
    normal_temperature:
      name: Normal temperature
      description: >
        The temperature at which the normal color is used.
        Must be between the minimum and maximum temperatures.
      default: 20
      selector:
        number:
          min: -50
          max: 100
          step: 0.5
          mode: box
    max_temperature:
      name: Maximum temperature
      description: >
        At or above this temperature, the hot color is used.
        Must be higher than the normal and minimum temperatures.
      default: 30
      selector:
        number:
          min: -50
          max: 100
          step: 0.5
          mode: box
    cold_temperature_rgb:
      description: >
        RGB color used at or below the minimum temperature.
      default: [0, 100, 255]
      selector:
        color_rgb:
    normal_temperature_rgb:
      description: >
        RGB color used at the normal temperature.
      default: [0, 255, 0]
      selector:
        color_rgb:
    hot_temperature_rgb:
      description: >
        RGB color used at or above the maximum temperature.
      default: [255, 0, 0]
      selector:
        color_rgb:
    cold_temperature_kelvin:
      name: Cold color temperature
      description: >
        Kelvin value used at or below the minimum temperature.
      default: 6500
      selector:
        color_temp:
          unit: kelvin
          min: 2000
          max: 6500
    normal_temperature_kelvin:
      name: Normal color temperature
      description: >
        Kelvin value used at the normal temperature.
      default: 4000
      selector:
        color_temp:
          unit: kelvin
          min: 2000
          max: 6500
    hot_temperature_kelvin:
      name: Hot color temperature
      description: >
        Kelvin value used at or above the maximum temperature.
      default: 2700
      selector:
        color_temp:
          unit: kelvin
          min: 2000
          max: 6500
    transition:
      description: >
        Duration of the color transition.
      default: 2
      selector:
        number:
          min: 0
          max: 60
          step: 0.5
          unit_of_measurement: seconds
          mode: box
    min_temperature_change:
      name: Minimum temperature change
      description: >
        Ignore temperature changes smaller than this amount.
        Set to 0 to react to every sensor state change.
      default: 0.5
      selector:
        number:
          min: 0
          max: 10
          step: 0.1
          mode: box
    only_update_lights_that_are_on:
      name: Only update lights that are already on
      description: >
        When enabled, off lights are never turned on by this automation.
        When a light is subsequently turned on, its color is synchronized
      default: true
      selector:
        boolean:
mode: restart
variables:
  temperature_sensor: !input temperature_sensor
  target_lights: !input target_lights
  color_mode: !input color_mode
  min_temperature: !input min_temperature
  normal_temperature: !input normal_temperature
  max_temperature: !input max_temperature
  cold_temperature_rgb: !input cold_temperature_rgb
  normal_temperature_rgb: !input normal_temperature_rgb
  hot_temperature_rgb: !input hot_temperature_rgb
  cold_temperature_kelvin: !input cold_temperature_kelvin
  normal_temperature_kelvin: !input normal_temperature_kelvin
  hot_temperature_kelvin: !input hot_temperature_kelvin
  transition: !input transition
  min_temperature_change: !input min_temperature_change
  only_update_lights_that_are_on: !input only_update_lights_that_are_on
  temperature: "{{ states(temperature_sensor) | float(0) }}"
  - trigger: state
    entity_id: !input temperature_sensor
    to: null
  - trigger: state
    entity_id: !input target_lights
    to: "on"
  - trigger: homeassistant
    event: start
condition:
  - condition: template
    value_template: >
      {{ is_number(states(temperature_sensor)) }}
    value_template: >
        min_temperature < normal_temperature
        and normal_temperature < max_temperature
    value_template: >
      {% if trigger.id != 'temperature_changed' %}
        true
      {% elif trigger.from_state is none %}
        true
      {% elif trigger.from_state.state in ['unknown', 'unavailable', 'none', ''] %}
        true
      {% else %}
            - trigger.from_state.state | float(0)
          ) | abs >= min_temperature_change
      {% endif %}
  - variables:
      lights_to_update: >
        {% if trigger.id == 'light_turned_on' %}
          {{ [trigger.entity_id] }}
        {% elif only_update_lights_that_are_on %}
            expand(target_lights)
            | selectattr('state', 'eq', 'on')
            | map(attribute='entity_id')
            | list
        {% else %}
          {{ target_lights }}
        {% endif %}
    value_template: >
      {{ lights_to_update | count > 0 }}
  - choose:
      - conditions:
            value_template: "{{ color_mode == 'rgb' }}"
        sequence:
          - variables:
              red: >
                {% set t = temperature | float(0) %}
                {% if t <= min_temperature %}
                  {{ cold_temperature_rgb[0] | int }}
                {% elif t < normal_temperature %}
                          (t - min_temperature)
                          / (normal_temperature - min_temperature)
                          normal_temperature_rgb[0]
                          - cold_temperature_rgb[0]
                    ) | round(0) | int
                {% elif t < max_temperature %}
                          (t - normal_temperature)
                          / (max_temperature - normal_temperature)
                          hot_temperature_rgb[0]
                          - normal_temperature_rgb[0]
                    ) | round(0) | int
                {% else %}
                  {{ hot_temperature_rgb[0] | int }}
                {% endif %}
              green: >
                  {{ cold_temperature_rgb[1] | int }}
                          normal_temperature_rgb[1]
                          - cold_temperature_rgb[1]
                    ) | round(0) | int
                          hot_temperature_rgb[1]
                          - normal_temperature_rgb[1]
                    ) | round(0) | int
                {% else %}
                  {{ hot_temperature_rgb[1] | int }}
                {% endif %}
              blue: >
                  {{ cold_temperature_rgb[2] | int }}
                          normal_temperature_rgb[2]
                          - cold_temperature_rgb[2]
                    ) | round(0) | int
                          hot_temperature_rgb[2]
                          - normal_temperature_rgb[2]
                    ) | round(0) | int
                {% else %}
                  {{ hot_temperature_rgb[2] | int }}
                {% endif %}
          - action: light.turn_on
              entity_id: "{{ lights_to_update }}"
              rgb_color:
                - "{{ red }}"
                - "{{ green }}"
                - "{{ blue }}"
              transition: "{{ transition }}"
      - conditions:
            value_template: "{{ color_mode == 'color_temperature' }}"
        sequence:
          - variables:
              color_temperature_kelvin: >
                  {{ cold_temperature_kelvin | int }}
                          - cold_temperature_kelvin
                    ) | round(0) | int
                          - normal_temperature_kelvin
                    ) | round(0) | int
                {% else %}
                  {{ hot_temperature_kelvin | int }}
                {% endif %}
              color_temp_kelvin: "{{ color_temperature_kelvin }}"
Source
Repository and issue tracking:
