Temperature Calibration
Today I tried to calibrate my thermometers in Home Assistant, but I couldn’t find an easy way to adjust the readings. For example:
  • Adding +2°C to the temperature
  • Subtracting 10% from the humidity
It would be really helpful if there was a simple built-in option to apply these kinds of adjustments directly in Home Assistant, without needing templates or complex configurations.
Does anyone know if this is already possible? If not, could this be added as a feature in the future? I think it would make calibration much easier for many users.
Did you try this?
Compensation - Home Assistant
