Hey there, I try to use a Wemos D1 mini to contol the temperature in a cabinet.
For this I use a DHT22 to get the temp and the PWM output to set the fans speed. As an addition I want to have an override switch, which turned on deactivate the automatic adjustment of the fan and let me adjust it by hand using a slider. All of this should run on the ESP directly so even when it cant reach HA it should be able to controll the temperature.
In this particular setup I got two identical fans on seperate PWM pins. I want to keep it that way so I can set them to different speed easier in the futer (for now they are doing the exact same thing).
I got it generally setup and the Hardware is doing its job and I am able to controll it with the slider, but after the startup of the ESP when it gives me the first measurements from my DHT it wont start the fans. could anyone help me figure out what I am doing wrong.
esphome:
friendly_name: Lueftung_Server
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "xxx"
password: "xxx"
captive_portal:
text_sensor:
# Send IP Address
- platform: wifi_info
ip_address:
name: $friendly_name IP Address
# Send Uptime in raw seconds
icon: mdi:clock-start
# Send WiFi signal strength & uptime to HA
- platform: wifi_signal
name: $friendly_name WiFi Strength
update_interval: 60s
# RPM Signal from Fan
- platform: pulse_counter
pin:
number: D4
mode: INPUT_PULLUP
name: Fan Speed 1
unit_of_measurement: 'RPM'
filters:
- multiply: 0.5
count_mode:
rising_edge: INCREMENT
falling_edge: DISABLE
update_interval: 30s
pin:
number: D3
mode: INPUT_PULLUP
name: Fan Speed 2
filters:
- multiply: 0.5
count_mode:
- platform: dht
pin: D6
model: DHT22
temperature:
name: "Server Temperature"
accuracy_decimals: 3
on_value_range:
- above: 25.0
then:
if:
condition:
and:
- fan.is_off: server_fan_toggle_1
- fan.is_off: server_fan_toggle_2
then:
- logger.log: "Set fan level 100 over 25C"
- output.set_level:
level: 100%
- output.set_level:
level: 100%
- above: 20.0
below: 25.0
then:
if:
condition:
and:
then:
- logger.log: "Set fan level 66 over 20C"
- output.set_level:
level: 66%
- output.set_level:
level: 66%
- below: 20
then:
if:
condition:
and:
then:
- logger.log: "Set fan level 0 under 20C"
- output.set_level:
level: 0%
- output.set_level:
level: 0%
humidity:
update_interval: 5s
# This is a bit of overkill. It sends a human readable
# uptime string
# 1h 41m 32s instead of 6092 seconds
- platform: uptime
on_raw_value:
then:
- text_sensor.template.publish:
# Custom C++ code to generate the result
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
output:
# Wire this pin (15) into the PWM pin of your 12v fan
# ledc is the name of the pwm output system on an esp32
- platform: esp8266_pwm
pin: D1
frequency: "1000 Hz"
pin: D2
fan:
- platform: speed
output: server_luefter_1
name: Server LĂĽfter 1
on_turn_on:
- output.set_level:
level: !lambda |-
return id(server_fan_1_speed_override).state/100.0;
on_turn_off:
- logger.log: "Power of Fan turned OFF"
- delay: 1s
- output.set_level:
level: !lambda |-
if (id(server_fan_temperature).raw_state > 25){
return 1;}
else if (id(server_fan_temperature).raw_state > 20){
return 0.66;}
else
return 0;
- platform: speed
output: server_luefter_2
name: Server LĂĽfter 2
on_turn_on:
- output.set_level:
level: !lambda |-
return id(server_fan_2_speed_override).state/100.0;
on_turn_off:
- delay: 1s
- output.set_level:
level: !lambda |-
return 1;}
return 0.66;}
else
return 0;
number:
name: "Server Fan 1 Speed Override"
internal: false
max_value: 100.0
min_value: 0.0
step: 33.3
optimistic: true
mode: slider
on_value:
then:
if:
condition:
fan.is_on: server_fan_toggle_1
then:
- output.set_level:
level: !lambda "return x/100;"
name: "Server Fan 2 Speed Override"
internal: false
max_value: 100.0
min_value: 0.0
step: 33.3
optimistic: true
mode: slider
on_value:
then:
if:
condition:
fan.is_on: server_fan_toggle_2
then:
- output.set_level:
switch:
# Expose an ESP restart button to HA
- platform: restart
name: "Server Fan D1 Mini Restart"
