Temperature Controller
I’m using an Aqara Zigbee Thermostat and a room temperature sensor (currently with Better Thermostat) to control real room temperature. The temperature is currently just set manually in HA.
The Problem is that I have to touch the thermostat to see the current setting without having to access HA. A second problem is that I can’t change the temperature directly at the thermostat any more so I removed Better Thermostat.
Is there a thermostat/a cheap separate device (preferably Zigbee) that can be used to set a temperature and display this set temprature without having to touch it to read the remperature (i.e. with e-paper or passive LC-display)?
Since you are using a radiator valve type setup you could look into this guide for your setup needs:
