Hi list,
When i click on a temperature sensor, i see a bar chart … Is there a way to change the type of the graph ? i would prefer to see a line chart.
Thx
Michael
Hi list,
Thx
Michael
Which platform are you using?
unit_of_measurement is probably missing
it’s for an aeotec multisensor 6 through zwave.
Is it a parameter i need to put in the customize file ?
Using the same config, with version 0.45 , by default it’s a line chart … but with 0.54, it’s bart chart. Something has changed between the two versions.
Ok, i found. It was the unit_of_measure finally.
In customize.yaml :
sensor.aeotec_zw100_multisensor_6_relative_humidity_2_5:
friendly_name: Humidite haut
icon: mdi:water-percent
unit_of_measurement: ‘%’
The only thing that worked for me was to call the Service: recorder.purge with this json: { “keep_days”: “0” }
For my Aeotec 6 multisensor I changed the Command Options setting from Basic Set (default) to Binary Sensor Report first, before calling recorder.purge
