Temperature monitor with probe
Hi
Does anyone know of any good temperature monitors that have probes? I am not sure if the govee bluetooth stuff works in HA easily, and I am looking for something to monitor 2 channels (its to measure in/out temperature from my boiler). it doesnt need to have a screen but I need to get it into HA easily.
Any ideas?
(UK-based)
If you’re handy, maybe ESPHome and a few Dallas sensors? I use this to watch my HVAC / Air Conditioning coil performance. (Watch intake and exhaust temperature delta)
Any instructions on this?
I’ve been looking for the same thing for some time now (to replace/supplement an AZEL DS-60P Digital Temperature Gauge) as I measure the inflow and outflow of my heat source/radiant heating loops. The best I’ve found so far in my search is from Yolink (Environmental), but I have yet to purchase and try.
I am using Dallas (DS18B20) sensors connected to a Fibaro Smart Implant (Z-wave) to do exactly this. Boiler in, boiler out, hot water cylinder and local temperature. I also have a Fibaro Universal Binary Sensor working in the same way on my Koi pond.
ESP/RP2040 of choice + DS18B20 probes of choice + ESPHome = :thermometer: :rocket:
Depending on the mechanics of your boiler you might look for pre-made threads and get yourself some ready made dallas probes that fit directly :nut_and_bolt:
Also if you like things smart you eventually want to drop one more relay into the setup so you can have a fully fletched thermostat on your esp :mechanical_arm:
I also see that Shelly has a Temperature Sensor AddOn for some of their Relay unit, and since some of these relays can also measure power use, which is another component I’m looking to add, I may go this route.
