Temperature msg telegram
Hello, can you help me? I’m doing something wrong. I try to check the temperature (sensor ds18b20) every 10 minutes, and if the result is less than 20 degrees, it should send a telegram msg. Currently, it sends the message only once when you press the play button. How to make it so that the temperature is sent every 10 minutes in a telegram?
alias: temp_bath
description: ""
trigger: []
condition:
  - condition: numeric_state
    entity_id: sensor.bath_yellow
    below: 20
  - service: telegram_bot.send_message
      message: "{{ states('sensor.bath_yellow') }}"
  - delay:
      hours: 0
      minutes: 10
      seconds: 0
      milliseconds: 0
mode: restart
  - platform: time_pattern
    minutes: "/10"
condition:
    below: 20
mode: single
A better option would be to create a template binary sensor that is on whenever your temperature is below 20 and use an alert:
thank you very much
helped
