Temperature not firing, possible conversion issue?
I have a read a few, other, posts on temp triggers, and confirmed I see to be “ok” with any issues they had.
Issue: Triggers set to a threshold are not executed when entity state clearly has crossed threshold.
Exhibit A (config) shows automation rule, and triggers. Exhibit B (developer tools state screenshot) shows current temperature is indeed centigrade, and history crossing threshold of 20, and finally exhibit C (history) shows the entity previously being above that threshold.
The trigger I care about specifically is the “very_cold” @ 20 degrees.
Really appreciate any thoughts or tips to debug this!
Exhibit A - The Rule:
alias: "zGrows: Big Tent - Climate Control"
description: ""
  - id: too_humid
    platform: numeric_state
    entity_id: sensor.big_tent_humidity
    for:
      hours: 0
      minutes: 1
      seconds: 0
    above: 68
  - id: too_hot
    entity_id: sensor.big_tent_temperature
    above: 25
    for:
      hours: 0
      minutes: 10
      seconds: 0
  - id: warm_enough
    above: 23
    for:
      hours: 0
      minutes: 5
      seconds: 0
  - id: too_dry
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 42
  - id: too_cool
    attribute: temp
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 22
  - id: very_cool
    attribute: temp
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 20
condition: []
  - if:
      - condition: trigger
    then:
      - type: turn_off
        device_id: 2632028e25b6132400a16b2031b2268b
        entity_id: switch.heater
        domain: switch
    else:
      - if:
        then:
          - type: turn_on
            domain: switch
  - if:
      - condition: or
        conditions:
          - condition: and
            conditions:
              - condition: not
                conditions:
                  - condition: numeric_state
                    below: 20
    then:
      - type: turn_on
        entity_id: switch.vents
        domain: switch
    else:
      - type: turn_off
        domain: switch
mode: single
Exhibit B - Current Entity State (from developer tools)
Temp is currently below 22, and went as low as 18 last night.
(the rise in temp is not from this rule, but greenhouse light on timed trigger sep. rule )
rule never fired
Exhibit C - Previous temperature was above 22
Screen Shot 2022-11-10 at 7.14.59 AM
What does the trace show?
Stupid question…
Have you RESTARTED Home Assistant after creating / changing the automation??
I had the same issue… after a restart… all worked
Nevermind, your problem is you’re using attribute: temp when you want the main state. Remove that line from all your triggers because there is no temp attribute.
Appreciate the tip. I have, I actually migrated to a refurbished minipc recently so its been rebooted MANY times (was crashing on old pi and migration was a few restarts for sure.
hmm, good call ! ill try that. (i dont recall selecting any attributes, didnt even see that!)
