todaxtream
(Shane Mclaren)
February 20, 2022, 6:10pm
1
Hellp im i have a baseboard heater connected thru a ssr, i want it stay between a certain temperature, i tryed a few diffrent things but with no success ,
- platform: dallas
address: 0xea3c01f096845628
name: "Wellhouse Temperature"
on_value_range:
- below: 8.0
then:
- switch.turn_on: heater
- above: 10.0
then:
- switch.turn_off: heater
the heater switch shows up in entities and does work, and the temperature is working but just not the automation part
BebeMischa
(Bebe Mischa)
February 20, 2022, 6:47pm
2
You may want to use a thermostat:
todaxtream
(Shane Mclaren)
February 20, 2022, 6:52pm
3
im trying to keep it just on the espboard, so that if my wifi every fails or ha fails the heater will run still run, this is all in my wellhouse
Mikefila
(Mike Fila)
February 20, 2022, 9:01pm
4
Set up a climate entity .
climate:
- platform: thermostat
name: "Thermostat Climate Controller"
sensor: my_temperature_sensor
default_target_temperature_low: 20 °C
min_heating_off_time: 300s
min_heating_run_time: 300s
min_idle_time: 30s
heat_action:
idle_action:
todaxtream
(Shane Mclaren)
February 20, 2022, 10:47pm
5
i tryed that one, didnt work
- platform: dallas
on_value_range:
- above: 8.0
below: 6.0
then:
- below: 6.0
then:
- above: 8.0
then:
got that working
todaxtream
(Shane Mclaren)
February 21, 2022, 1:27am
6
ok apparently this isnt working eather, ill try the climate entry again
todaxtream
(Shane Mclaren)
February 21, 2022, 3:35am
7
Soo that isnt working correctly eather, im just looking for something simple two turn off and turn on at two set values
Mikefila
(Mike Fila)
February 21, 2022, 5:27am
8
This should work
- platform: dallas
on_value_range:
- below: 6.0
then:
- above: 8.0
then:
BebeMischa
(Bebe Mischa)
February 21, 2022, 11:14am
9
What is the difference between this and the initial post? (other dan the values)
edit: oh, I see, some spacing
