Im new to Home Assistant and being doing a lot of research to try finding a solution.
I am looking to control a damper with a relay toggle on/off (Sonoff). with a temperature sensor (Sonoff) to open and close when the temperature is reached but with a 2-3 degree differential for controling relay.
Ex: target temps is 22 relay OFF at 19 relay toggles to ON and gos OFF when rechead 22 and when the temps get to 25 relay toggles to ON and gos OFF at 22 to target temps.
I Have been loking to the generic Thermostat or dual thermostant but it dosent seem to work for me.
did a lot of texting
This is something that im tring to do but not convince
@Hellis81
What do you mean by the climate entity is on ?
exemple of what i whant to
----on to open damper when below 20 to get temp back to 22 (Target)------><-----off to close the damper whent target reached 22-----><-----on When over 24 to get the temps back to 22 (target)
So it’s not a heating entity? In that case you need to set AC_mode: true in the generic thermostat (look at the documents because I’m not completely sure about the correct syntax)
In that case you need two generic thermostats or one of the custom component versions that has dual action.
But whichever route you go, you will not need automations if you configure it correctly
If that is the case then it’s just a AC_mode generic thermostat.
When the temperature is “hot”, the generic thermostat turns on → turns on the switch to open the damper → room cools down.
Correct?
Then the room is at correct temperature and the thermostat goes off → switch off → spring closes damper → room heats up again.
Correct? Yes
? Yes
And
When the temperature is “cold”, the generic thermostat turns on → turns on the switch to open the damper → room heats up again.
This damper is related to a ductable unit whit 5 oulet
that the thermostat is located in the leving room set at 23.
but in Edrick room the duct that feeds the room is close to the unite so the room go up fast in heat or when in cooling mode go cold fast to. This is why a need to control the damper.
