Temperature sensor/ deep_sleep/ avoid first reading
Good afternoon. I’m using an esp32-c3 with a bme280 sensor. I’m using battery in deep_sleep.
I have “sleep_duration: 5min” and “run_duration: 3min” and the sensor has “update_interval: 175s”
The intention is that, when the esp32-c3 wakes up, it waits for the sensor temperature to remain stable, and only then sends the temperature reading. This is to avoid sending too low a temperature.
The problem is that as soon as the esp32-c3 wakes up the temperature value is updated, giving a lower value and 175 seconds later it gives a higher value.
Is there a way to avoid sending this first value when the board is still cold?
captive_portal:
i2c:
  sda: GPIO6
  scl: GPIO7
  - platform: bme280_i2c
    temperature:
      filters:
        - offset: 0.0
    humidity:
      accuracy_decimals: 0
      filters:
        - offset: 0
    address: 0x76
  - platform: adc
    pin: GPIO2
    attenuation: 11db
    accuracy_decimals: 1
    filters:
      - multiply: 2.0292
deep_sleep:
  run_duration:
    default: 3min
    gpio_wakeup_reason: 3min
  wakeup_pin:
    number: GPIO3
    inverted: True
button:
    entity_category: diagnostic
    on_press:
      - deep_sleep.enter:
    on_press:
      - deep_sleep.prevent:
THS :+1:
There is a filter skip_initial
https://esphome.io/components/sensor/#skip-initialSensor Component — ESPHome
Hello and thanks for your help… During the “skip_initial” period the sensor appears as unknown.
It’s a filter I haven’t used before, so I can’t say if that is the expected behavior or not. The sliding window filter can also skip the first couple of readings as well. However if you need exact values, that filter will average readings.
I think you are overthinking this. The BME280 sensor can’t be at a lower temperature than the area that you are looking to measure temperature if it’s temperature has equalized.
This sounds like you are waiting for the rate at which the BME absorbes energy to be the same rate at which it radiates energy but the temperature of the BME will not be at the same temperature of the area. I suggest just get the first reading the sensor reads and send the ESPhome device back to deep sleep. Heat creep is a problem with sensors like this. Temperature is all relative. 1 foot above your sensor will be different from the senor or 1 foot to the left or 3 feet in front of it.
I changed sensors and now the first reading is the same as all the readings taken during the “wakeup” period
Old post I know,… but having the same issue when coming out of deep sleep. Works fine with readings when running, and seems to be ok if just deep sleep for say 5 minutes, but if I set too say, 1 hours deep sleep, I get negative readings from the sensor when it wakes up. Even if leaving awake for a while it never seems to settle. Powering off the esp completely then back is only way to get the I2C readings working again.
Voltage is all fine.
Interested to know what sensor you ended up changing too?
