Temperature Sensor not showing values (Tuya)
I have a Temperature Humidity Sensor and would like to connect it to Home Assistant.
I followed this tutorial: Tuya - Home Assistant
Everything works pretty good and I could add the item to my home assistant instance.
It’s visible there but not showing values (top image)
In the tuya iot page, it shows the device as Offline, which is weird (bottom image)
However, in the device logs, it sees the temp and humidity values, which makes me think it works properly (right image)
Do you have any idea of what I missed or how to debug the issue in home assistant?
Thanks!
Having the exact same issue.
My uneducated guess is that the phone is functioning as the bluetooth hub instead of the device that HA is running on. I’ve got to figure out how to connect my Tuya thermometer directly to my RPi.
I have the same problem. HA says not available. Did you got it working?
