Hi!
I have installed HA OS in a VM and its working fine. It has found my devices from philips hue, and some others.
I am trying to get a temperature sensor from Philips, to control a smart plug (which has an oven connected to the smart plug).
I am unable to get it to trigger automatically. I have made this automation, just to test the setup.
alias: Ovn Stue Av
description: Slå av ovn i stue over gitt temperatur.
- type: temperature
platform: device
device_id: 2941d140e8b5497d05bb51af2c86dc6b
entity_id: sensor.hue_motion_sensor_2_temperature
domain: sensor
above: 22
condition:
- type: is_temperature
condition: device
domain: sensor
above: 22
- type: turn_off
device_id: 87bbde2ea635327b35a9e36f3182cc48
entity_id: light.ovn_stue
domain: light
mode: single
What I do now to test is the following:
- Turn on the oven in the living room manually.
- Check manually the temperature from sensor.hue_motion_sensor_2_temperature and its below 22.
- I am running the automation automatically, and as far as I understand it should NOT turn the oven off because the temperature is below 22. But it turns it off when I run it manually.
I run it manually, because it doesnt seem to do it by itself? What am I missing?
Apprechiate any advice, or pointers to where I can find out how to this simple setup. I have tried watching some youtube videos, and reading the documentation. Someone talks about trying the “Generic Thermostat” addon? but I cant find that anywhere?
