Hi to all,
I’ll tell you my case to see if you can help me. I have a TS0601 temperature sensor on Zigbee2MQTT. It works fine, but the readings it gives me seem to triple. Let me explain, it takes my temperature, but it takes very frequent and changing temperatures at that same moment (see example). I have this sensor monitored, I am saving the values, so saving many values at all times makes it take up a lot of space. Does anyone know how I can cancel readings in Home Assistant?, I just need one value. That is, it only tells me the average reading, a single temperature (I attach an image along with another sensor from another manufacturer as an example). Thank you.
If anyone can help me I appreciate it.
