Hi guys I’m having problem with automation of if temperature changes below x and above x then turn on AC on certain room.
Previously I have been using a set up time and it worked alright. Then I bought Tuya temperature sensor and hasn’t able to get the function above working.
I’ve tested that the conditions are all good to go but it never kicked off. Where do I do wrong? Screenshots below are two different tests that I have. Both doesn’t work.
Hi sorry I am still very new. I believe below is the code:
alias: AC On (BR) - Cold Season
description: >-
To turn on AC around 6:30 PM - 5:00 AM when the temperature is below 22°C for
Baby Room
