I have a series of sensors which report temperature in F and not in C.
Home assistant does change F to C but its been a long time since I have had to replace the sensor. Ive recently replaced one and after a day it still has not changed to C.The question is how long does this automatic conversion take? Can it be prompted to change?
I know that according to this post you have to add the degree symbol for it to convert automatically.
Temperature Desk
- name: "desk_temp"
state_topic: "rtl_433/43/temperature_F"
unit_of_measurement: "°F"
123
TarasRegular
Dec '21
It’s the inclusion of °F or °C in unit_of_measurement that serves as a flag for Home Assistant to perform an automatic temperature conversion to the base temperature unit system.
For example, if your Template Sensor’s template performed a conversion from Celsius to Fahrenheit and the result was 20, the automatic conversion would also kick in and produce a final result of -6.7. By dropping the ° symbol, the resulting unit_of_measurement no longer serves as a conversion flag.
From https://community.home-assistant.io/t/displaying-temps-in-both-c-and-f/371099/5
Solution, add this to the sensor statement in configuration.yaml
device_class: temperature
For example:
mqtt:
- name: "desk_temp"
