Looking for some help with creating a temperature trend sensor that can monitor an outdoor sensor and indicate if temperature is rising, falling or steady (1 degree rise or fall per hour otherwise steady). I was able to get this using 2 different trend helper sensors that indicate hot or cold based on rising or falling temps but I would like to combine this into one sensor that I can have a history graph on and use for automation. Any help with this would be appriciated.
So you have two of these?
And you want a single sensor to tell you these states?
- Rising
- Falling
- Steady
You could do something like this:
template:
- sensor:
- name: Temperature Trend
state: >
{% if is_state('binary_sensor.rising','on') %}
Rising
{% elif is_state('binary_sensor.falling','on') %}
Falling
{% else %}
Steady
{% endif %}
icon: >
mdi:thermometer-chevron-up
mdi:thermometer-chevron-down
{% else %}
mdi:thermometer-minus
{% endif %}
Thank you, that seems to be working perfectly.
In your template sensor, I am facing a problem in this; by using 2 trend sensors, it can only show Rising and Falling, not steady state.
This is the code I am using to show steady state using 2 trend sensors. You just have to fine tune the trend sensor’s parameters to accurately indicate temperature not rising or falling.
type: custom:mushroom-entity-card
entity: sensor.indoor_outdoor_meter_7465
name: Outdoor Temperature
icon_type: icon
icon_color: white
card_mod:
style: |
:host {
--card-mod-icon:
{% if 'Rising' in states('sensor.outdoor_temperature_trend') %}
{% elif 'Falling' in states('sensor.outdoor_temperature_trend') %}
{% else %}
mdi:thermometer-lines
{% endif %};
{% if states('sensor.indoor_outdoor_meter_7465') | round(1) > 25 %} --card-mod-icon-color: red;
{% elif states('sensor.indoor_outdoor_meter_7465') | round(1) < 5 %} --card-mod-icon-color: Blue;
{% else %} --card-mod-icon-color: green;
{% endif %}
I also have below template sensor that can show steady temperature:
{% if is_state('binary_sensor.temp_rising','on') %}
Rising
{% elif is_state('binary_sensor.temp_falling','on') %}
Falling
{% else %}
Steady
{% endif %}
Hi, can you explain how you make the trend sensor? I been triying for almost a month hahahah, and im sure its gonna be easy but i cant figure it out
Did you follow the manually config step outlined on: Trend - Home Assistant
yeap, but i cant get it to work correctly
What exactly are you running into, post errors or screenshots so the community can help.
I am trying to do exactly the same. Tried the trend sensor this week but run into some jargon where I am not sure what to do.
I have several aqara temperature sensors and two sensores for outside and started with just one.
Here is how I setup the trend - I may have made mistakes
Options, I took value from the documentation example
I also added this sensor to configuration.yaml to be recorded
If I now click on the trend it shows no data
Thank you very much! Tried this and can confirm it works (after waiting some time). I think the trick was to keep the attribute open but at least it works now ![]()
Everything works based on one sensor (measuring temperature rise). If it rises its on, otherwise off.
I notice in dashboard that its always rising or falling, never steady. Without jumping into code - is this the correct way to get a decent steady state?
- create a sensor for temperature rising (set parameter such that a decent rise is needed for it to be ON, otherwise off)
- create another sensor for temperature falling (set parameter such that a decent decline needed for it to be ON, otherwise off)
- create a mechanism that checks both sensors, if neither are on then its steady - from post 5 above:
Rising
Falling
{% else %}
Steady
{% endif %}
Just trying to understand what I need to achieve before trying it. Where do I put the code copied above? I think it is a template sensor from post above, I think they can be made both via helpers or in config.yaml - can someone point me how to make this template sensor please?
Am I correct this goes in config.yaml?
- sensor:
- name: "newsensorname"
state: >
{% if is_state('binary_sensor.temptrend_knmi_up','on') %}
Rising
{% elif is_state('binary_sensor.temptrend_knmi_down','on') %}
Falling
{% else %}
Steady
{% endif %}
Once you have the rising and falling trends working properly, you can use below code to create a helper template sensor:
Rising
Falling
{% else %}
Steady
{% endif %}
Thanks again! Just double checking my sensors now for correctly working, then will take this next step. Appreciated!!
Still bit puzzled by trend documentation. Not native English.
For a temperature down trend
E.g. -0.000278
Should I select invert?
Or does it magically understand now that trend is negative and read -0.000279 and lower as exceeds?
Or is -0.000277 exceeding this like temp up and triggering an on state?
You need to put a negative value for falling temperature (think of it as positive and negative slopes), see below example.
Thanks again ![]()
No problem, hope you managed to get it working.
So just curious, followed the chat and I am trying to configure a device temperature attribute which I create a sensor for but it is not working, it is working for thermostats which have a temperature entity out of the box so to speak.
So my question is if it is possible to create a trend tracking helper for a sensor which was created from a device attribute, or is there another way to achieve this?
And just to add I have successfully create history tracking charts for the said temperature sensor but can’t seem to create a trend helper for the same.
