Just started with the Lovelace UI and it looks very promising!
I would like to show a picture glance card for every room on my main page, not a problem…
But instead of the thermometer icon for the room temp I would love to see the actual temperature. Is this anyway possible?
Same here. I just had a look at lovelace and was impressed but when I saw that this is not possible I did not continue… You need the Picture Elements Card to see the values at first “glance”, which means far more work.
There is a discussion about it at github, I hope there might be a way to realize this in the future.
For now it is not possible.
@DonTomato@PaNiCo, showing status on the picture-glance is not possible. It only shows the icon. I cannot say if that will change. Remember, lovelace is it’s early stages. Lots of changes are happening every build. To keep up with new changes, follow the change log:
As for your problem. You can use the picture glance card inside a vertical stack with a normal glance card. Put all your lights and switches in the picture glance, and all your sensors in the glance card. You’ll get what looks like a nice 2 panel window with all the information together for that room. Don’t label the glance card and it will be condensed. Only label the picture glance card.
this is an example I use with slider bars… imagine the sliders bars are replaced with a glance card:
Sorry to revive this. I want to achieve the same thing, but with a camera image as background. I tried the temperature-glace solution by @ teachingbirds, but the picture-elements card requires an image and doesn’t work with a camera, so it won’t work for me
Any other ideas?
I am currently using a picture glance card, but the temperature sensor is shown as a thermometer icon, and I’d like to see its value instead (without clicking on the icon).
There’s a camera image overlayed on top of a static image. When the camera is unreachable I can see the static image below (neat). I can also add items like a normal picture-elements card. I don’t have the transparent gray bar below, but so far it’s not an issue.
