Template action response_variable undefined
Hi experts,
I really spend a lot of time with this. I want to use the temperature of tomorrow in an automation. I created the trigger and template sensor. Everything seems correct but I always get:
The action works correctly:
If I use the template editor. The parsing of the value looks also good:
My template config
- trigger:
    - trigger: time_pattern
      minutes: "/5"
    - trigger: homeassistant
      event: start
    - action: weather.get_forecasts
        type: daily
        entity_id: weather.sandfeld13
      response_variable: daily_forecast
- sensor:
    - name: Temperature forecast next day
      unique_id: temperature_forecast_next_day
      state: >
        {{daily_forecast['weather.sandfeld13'].forcast[1].templow}}
The action should at least be triggered on HA start but I always get:
TemplateError('UndefinedError: 'daily_forecast' is undefined') while processing template 'Template<template=({{daily_forecast['weather.sandfeld13'].forcast[1].templow}}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.temperature_forecast_next_day'
Logger: homeassistant.helpers.event
Source: helpers/template.py:633
First occurred: 15:00:17 (1 occurrences)
Last logged: 15:00:17
Error while processing template: Template<template=({{daily_forecast['weather.sandfeld13'].forcast[1].templow}}) renders=2>
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 631, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2733, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1304, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 939, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
  File "/usr/local/lib/python3.13/site-packages/jinja2/sandbox.py", line 304, in getitem
    return obj[argument]
jinja2.exceptions.UndefinedError: 'daily_forecast' is undefined
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 748, in async_render_to_info
    render_info._result = self.async_render(  # noqa: SLF001
        variables, strict=strict, log_fn=log_fn, **kwargs
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 633, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'daily_forecast' is undefined
Any idea? Im using HA version 2024.12.3
Thanks in advance!
Kind regards,
Marco
Replace the hyphen before sensor: with a space. Your current version is defining a separate sensor to the trigger and action.
You also have a typo in forcast.
Thank you very much. Works really well :partying_face:
Getting a daily forecast every 5 minutes is a bit more frequent than necessary, too… :slightly_smiling_face:
in all likelihood, the 5 minute interval will just return cached values. It depends on the integration.
Sure, that was just for debugging. Thanks again.
