using template sensor:
count_earthquakes:
friendly_name: Earthquakes
value_template: >
{{ states.geo_location|selectattr('attributes.source','eq','usgs_earthquakes_feed')|list|count }}
icon_template: >
{% if states('sensor.count_earthquakes')|int != 0 %} mdi:google-earth
{% else %} mdi:earth
{% endif %}
and binary template sensor:
earthquakes_active:
friendly_name: Earthquakes active
value_template: >
{{states('sensor.count_earthquakes')|int > 0 }}
icon_template: >
{% if is_state('binary_sensor.earthquakes_active','on') %} mdi:flash-alert
{% else %} mdi:flash-off
{% endif %}
shows me:
which is beyond me, because the bottom Earthquakes sensor show this in the dev-template:
iow, it should be showing mdi:google-earth, while the dev-state shows:
which is what is actually shown…
what am I missing here?
the binary sensor is incorrect also, in that it doesn’t show at all.
it should however show mdi:flash-alert according to the template:
as is confirmed in the dev-state:
so.both sensors puzzle me.
please have a look, thanks!
lolouk44
(lolouk44)
August 23, 2019, 11:19am
2
You may want to try and add the entity that the template sensor needs to monitor to update itself:
earthquakes_active:
entity_id: states.geo_location
value_template: >
ok I will do that, to ensure proper updating of the sensor.
It wouldn’t however explain the icon being displayed would it? To be sure the entity state was updated, I had manually serviced that, so if everything was as it should be, the templates above and the actual state should have been identical…
as an update:
the states.geo_location wouldn’t trigger the template sensor. I had to do it manually to have the sensor change its state, even while the states.geo_location sensors where created.
so I ended up using sensor.time, which now shows correct sensors even at startup.
using this for now:
binary-sensor:
sensors:
lightning_active:
friendly_name: Lightning active
# entity_id: sensor.count_lightning_strikes
value_template: >
{{states('sensor.count_lightning_strikes')|int > 0 }}
icon_template: >
{% if is_state('binary_sensor.lightning_active','on') %} mdi:flash-alert
{% endif %}
earthquakes_active:
# entity_id: sensor.count_earthquakes
value_template: >
device_class: safety
# icon_template: >
# {% if is_state('binary_sensor.earthquakes_active','on') %} mdi:alert
# {% else %} mdi:shield-check
# {% endif %}
and
sensors:
# https://community.home-assistant.io/t/conditional-map/132739/4
count_lightning_strikes:
entity_id: sensor.time
friendly_name: Lightning strikes
value_template: >
{{ states.geo_location|selectattr('attributes.source','eq','wwlln')|list|count }}
count_earthquakes:
value_template: >
customizations work now too, (I’ve left the previous tests commented as reference)
binary_sensor.lightning_active:
templates:
icon_color: >
if (state === 'on') return 'red';
return 'green';
# icon: >
# if (state === 'on') return 'mdi:flash-alert'
# return 'mdi:flash-off';
sensor.count_lightning_strikes:
templates:
icon_color: >
if (state !== '0') return 'red';
return 'green';
icon: >
if (state !== '0') return 'mdi:weather-lightning';
binary_sensor.earthquakes_active:
templates:
icon_color: >
return 'green';
# icon: >
sensor.count_earthquakes:
templates:
icon_color: >
return 'green';
icon: >
if (state !== '0') return 'mdi:google-earth';
return 'mdi:earth';
to make this in Lovelace:
- type: custom:vertical-stack-in-card
cards:
- type: entities
title: Quakes
show_header_toggle: false
entities:
- binary_sensor.earthquakes_active
cards:
- type: conditional
conditions:
- entity: binary_sensor.earthquakes_active
state: 'on'
card:
type: map
# dark_mode: true
entities:
- device_tracker.life360_daughter2
geo_location_sources:
- usgs_earthquakes_feed
# title: Quakes conditional map
default_zoom: 6
aspect_ratio: '2'
- type: custom:monster-card
show_empty: false
card:
type: entities
# title: Earth quakes
filter:
include:
- entity_id: sensor.count_earthquakes
- domain: geo_location
and show up as:
