Hope someone can help me to understand.
I have several templates which build with the following pattern:
template:
- sensor:
- name: "AZ HC power"
unique_id: "az_hc_power"
unit_of_measurement: "W"
attributes:
radiatorpower: "2782"
state: >
{% set pers = states('sensor.az_thermostat_valve_state') | float (0) %}
{% set power = state_attr("sensor.az_hc_power","radiatorpower") | float (-1) %}
{% if pers == 'unknown' %}
0
{%- else %}
{{ (power*pers/100) |round(0) | int }}
{% endif %}
As
My understanding: this. can be a reference to the current sensor:
so:
{% set power = this.attributes.radiatorpower | float (-1) %}
shall lead to the same result, but lead to some kind of error.
Can someone give me a hint ?
By the way: Would it be possible to add to expand an integrated sensor by additional attributes and do such calculations instead of having a dedicated template ? E.g. the homematic thermostat ?
Thank you very much !
I tested it and it works finde. Only drawback:
I have several of those templates and only want to change as less as possible inside of the template to have more or less the same “code”. If I use the e.g. instead of “default(2782)” (the number is different for each template) with “default(0)” I got no error but the value is wrong until the value “sensor.az_thermostat_valve_state” changes the next time.
So I can use this, but unfortunately it has no advantage in this case.
Nevertheless I learnd something ! One additional topic is, that my cool idea with the " {% if pers == ‘unknown’ %}" will not work because the problem that I I would like to avoid occurs while float conversion.
