Hey guys, I’m trying to set a remaning hours fan filter sensor.
sensors:
filtro_purificatore:
value_template: >
{% if is_state('state.fan.xiaomi_miio_device.filter_life_remaining', '15') %}
Change filter
{% else %}
Filter ok
{% endif %}
I can see the new sensor in HA, but it is stucked at ‘Filter ok’ even if filter_life_remaining is under 15
tom_l
March 26, 2020, 11:28am
2
sensors:
value_template: >
{% if is_state_attr('state.fan.xiaomi_miio_device', 'filter_life_remaining', '15') %}
Change filter
{% else %}
Filter ok
{% endif %}
Though you might be better off with:
sensors:
value_template: >
{% if state_attr('state.fan.xiaomi_miio_device', 'filter_life_remaining')|int <16 %}
Change filter
{% else %}
Filter ok
{% endif %}
This way it will tell you to change the filter if the life remaining is 15 or less . In case you miss it when it is 15 and it changes to 14. In your original template this would result in “Filter OK” again.
