Template binary_sensor error "got '<scalar>'"
Trying to create a template sensor to combine a people group and an input_boolean to know if the home is occupied by either people or a ‘guest mode’.
binary_sensor:
    sensors:
      home_occupied:
        friendly_name: "Home Occupied 2"
        unique_id: ishomeoccupied
        device_class: occupancy
        value_template: {{ is_state('group.family_home', 'home') or is_state('input_boolean.guest_mode', 'on') }}
When I try to use this I get the following error:
Error loading /config/configuration.yaml: while parsing a flow mapping
in "/config/configuration.yaml", line 21, column 26
expected ',' or '}', but got '<scalar>'
in "/config/configuration.yaml", line 21, column 64
line 21 is the value_template line.
I’ve read a bunch of documentation but cannot find help with this particular error.
single line templates require quotes on the outside and need to be different than on the inside:
value_template: "{{ is_state('group.family_home', 'home') or is_state('input_boolean.guest_mode', 'on') }}"
:man_facepalming:
Thank you. I could have sworn that I had quotes there at one point.
