Aldopez
(Aldopez)
June 11, 2022, 3:59pm
1
I’m trying to make a movemente sensor from a motioneye webhook (start and end event). Im using motion_width data to do it. If I define a template sensor i can see the postive value when motion is detected and 0 when the end webhook is called. But when I convert the sensor to binary is always “not detected”
- trigger:
- platform: event
event_type: motioneye.motion_detected
event_data:
device_id: a00af3f7f4b09e2cdad71d230ea8af96
- platform: event
event_type: motioneye.motion_ended
event_data:
binary_sensor:
- name: Movimiento Living
state: "{{ trigger.event.data.motion_width | int }}"
device_class: motion
What i’m doing wrong?
Dujith
(Charles Evers)
June 11, 2022, 4:08pm
2
In the dev tools, what does {{ trigger.event.data.motion_width | int }}
produce?
Aldopez
(Aldopez)
June 11, 2022, 11:41pm
3
It’s possible to test a template based on event’s data?
For testing purposes I’ve defined this sensor
- trigger:
- platform: event
event_data:
- platform: event
event_data:
- name: Movimiento Living (no motion)
It show >zero or zero when movement is detected or not
Aldopez
(Aldopez)
June 12, 2022, 12:57am
4
Solved!
Just in case there is anyone interested. This is my correct code to generate a binary_sensor using the webhooks from motioneye for detect movement.
template:
# Template motion sensor camara Living
- trigger:
- platform: event
event_data:
binary_sensor:
state: "{{ trigger.event.data.motion_width | int > 0}}"
You need to set the “ended webhook” manually in motioneye for this to woek. Just copy the start webhook text activate and paste below
Thx
Aldopez
(Aldopez)
June 12, 2022, 4:21am
5
I forgot to mark my last post as the Solution… thx @tom_l
