Just upgraded to the latest HA core-2021.10.0 and get hundreds of template warnings like this :
2021-10-06 22:16:45 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_custom' got invalid input '00:00' when compiling template
'{% if (states.sensor.time.state >= ('00:00' | timestamp_custom('%H:%M', False))) and (states.sensor.time.state < ('00:30' | timestamp_custom('%H:%M', False))) %}
<Do some things...>
{% endif %}'
but no default was specified. Currently 'timestamp_custom' will return '00:00', however this template will fail to render in Home Assistant core 2021.12
So, I have no idea what Iām supposed to do here as clearley I donāt understand whatās going on. Why is ā00:00ā (or any time specified in this format) suddenly an invalid imput to the custom_timestamp filterā¦?
Donāt know, Donāt careā¦, handling time in HA has always been a over complex PITAā¦, lots of confising and contradictory stuff on the boards about thisā¦, so I reverted back to the most basic tests, which actually work:
{% if states.sensor.time.state >= '00:00' and states.sensor.time.state < '00:30' %}0000_to_0030
{% elif states.sensor.time.state >= '00:30' and states.sensor.time.state < '01:00' %}0030_to_0100
{% elif states.sensor.time.state >= '01:00' and states.sensor.time.state < '01:30' %}0100_to_0130
{% elif states.sensor.time.state >= '01:30' and states.sensor.time.state < '02:00' %}0130_to_0200
{% elif states.sensor.time.state >= '02:00' and states.sensor.time.state < '02:30' %}0200_to_0230
{% elif states.sensor.time.state >= '02:30' and states.sensor.time.state < '03:00' %}0230_to_0300
{% elif states.sensor.time.state >= '03:00' and states.sensor.time.state < '03:30' %}0300_to_0330
{% elif states.sensor.time.state >= '03:30' and states.sensor.time.state < '04:00' %}0330_to_0400
{% elif states.sensor.time.state >= '04:00' and states.sensor.time.state < '04:30' %}0400_to_0430
{% elif states.sensor.time.state >= '04:30' and states.sensor.time.state < '05:00' %}0430_to_0500
{% elif states.sensor.time.state >= '05:00' and states.sensor.time.state < '05:30' %}0500_to_0530
{% elif states.sensor.time.state >= '05:30' and states.sensor.time.state < '06:00' %}0530_to_0600
{% elif states.sensor.time.state >= '06:00' and states.sensor.time.state < '06:30' %}0600_to_0630
{% elif states.sensor.time.state >= '06:30' and states.sensor.time.state < '07:00' %}0630_to_0700
{% elif states.sensor.time.state >= '07:00' and states.sensor.time.state < '07:30' %}0700_to_0730
{% elif states.sensor.time.state >= '07:30' and states.sensor.time.state < '08:00' %}0730_to_0800
{% elif states.sensor.time.state >= '08:00' and states.sensor.time.state < '08:30' %}0800_to_0830
{% elif states.sensor.time.state >= '08:30' and states.sensor.time.state < '09:00' %}0830_to_0900
{% elif states.sensor.time.state >= '09:00' and states.sensor.time.state < '09:30' %}0900_to_0930
{% elif states.sensor.time.state >= '09:30' and states.sensor.time.state < '10:00' %}0930_to_1000
{% elif states.sensor.time.state >= '10:00' and states.sensor.time.state < '10:30' %}1000_to_1030
{% elif states.sensor.time.state >= '10:30' and states.sensor.time.state < '11:00' %}1030_to_1100
{% elif states.sensor.time.state >= '11:00' and states.sensor.time.state < '11:30' %}1100_to_1130
{% elif states.sensor.time.state >= '11:30' and states.sensor.time.state < '12:00' %}1130_to_1200
{% elif states.sensor.time.state >= '12:00' and states.sensor.time.state < '12:30' %}1200_to_1230
{% elif states.sensor.time.state >= '12:30' and states.sensor.time.state < '13:00' %}1230_to_1300
{% elif states.sensor.time.state >= '13:00' and states.sensor.time.state < '13:30' %}1300_to_1330
{% elif states.sensor.time.state >= '13:30' and states.sensor.time.state < '14:00' %}1330_to_1400
{% elif states.sensor.time.state >= '14:00' and states.sensor.time.state < '14:30' %}1400_to_1430
{% elif states.sensor.time.state >= '14:30' and states.sensor.time.state < '15:00' %}1430_to_1500
{% elif states.sensor.time.state >= '15:00' and states.sensor.time.state < '15:30' %}1500_to_1530
{% elif states.sensor.time.state >= '15:30' and states.sensor.time.state < '16:00' %}1530_to_1600
{% elif states.sensor.time.state >= '16:00' and states.sensor.time.state < '16:30' %}1600_to_1630
{% elif states.sensor.time.state >= '16:30' and states.sensor.time.state < '17:00' %}1630_to_1700
{% elif states.sensor.time.state >= '17:00' and states.sensor.time.state < '17:30' %}1700_to_1730
{% elif states.sensor.time.state >= '17:30' and states.sensor.time.state < '18:00' %}1730_to_1800
{% elif states.sensor.time.state >= '18:00' and states.sensor.time.state < '18:30' %}1800_to_1830
{% elif states.sensor.time.state >= '18:30' and states.sensor.time.state < '19:00' %}1830_to_1900
{% elif states.sensor.time.state >= '19:00' and states.sensor.time.state < '19:30' %}1900_to_1930
{% elif states.sensor.time.state >= '19:30' and states.sensor.time.state < '20:00' %}1930_to_2000
{% elif states.sensor.time.state >= '20:00' and states.sensor.time.state < '20:30' %}2000_to_2030
{% elif states.sensor.time.state >= '20:30' and states.sensor.time.state < '21:00' %}2030_to_2100
{% elif states.sensor.time.state >= '21:00' and states.sensor.time.state < '21:30' %}2100_to_2130
{% elif states.sensor.time.state >= '21:30' and states.sensor.time.state < '22:00' %}2130_to_2200
{% elif states.sensor.time.state >= '22:00' and states.sensor.time.state < '22:30' %}2200_to_2230
{% elif states.sensor.time.state >= '22:30' and states.sensor.time.state < '23:00' %}2230_to_2300
{% elif states.sensor.time.state >= '23:00' and states.sensor.time.state < '23:30' %}2300_to_2330
{% elif states.sensor.time.state >= '23:30' and states.sensor.time.state <= '23:59' %}2330_to_0000
{% endif %}
This is used to set the correct 30min tariff on a utility_meter. Any better way of doing this ?
For example, timestamp_custom expects to receive a timestamp but you supplied it with a string:
00:00 is not a timestamp, itās a string and in previous versions this mistake would be ignored and the result of timestamp_custom would simple be the string itself (i.e. it would ignore whatever pattern you supplied and simply pass the string as-is). Whatever you think you were trying to achieve with the timestamp_custom function, it wasnāt actually doing it.
2021.10.0 now flags mistakes like that (with a warning message). 2021.12.0 will cause an error message.
Yes. This computes the time-range that the current time falls into without requiring sensor.time.
{% set h = now().hour %}
{% set m = now().minute %}
{{'{:02d}{:02d}_to_{:02d}{:02d}'.format(h, 0 if m < 30 else 30, h if m < 30 else h+1 if h < 23 else 0, 30 if m < 30 else 0) }}
Just a quick question if you donāt mind. Iāve been on the Jinja docs, and the Python docs, and even stackoverflow. But I canāt find the answer. Are the colons the same as % in Python formatting?
Awsome, thanks⦠Been trying to squash various warnings in my (hacky) templatesā¦, but this is still bugging meā¦
TemplateError('UndefinedError: 'mappingproxy object' has no attribute 'results'') while processing template 'Template("
{% if states.sensor.octopus_agile_daily_tariff is defined %}
{% if states.sensor.octopus_agile_daily_tariff.attributes is defined %}
{% if states.sensor.octopus_agile_daily_tariff.attributes.results is defined %}
<Some other Stuff>
So, asking if an attribute is defined throws an error because its not defined ???
I think it might be related to another sensor in the template, its just not logging the error correctly.
I have several command line sensors that get electricity tariffs from a public API. When these fail (as they sometimes do), I canāt work out how to catch the error eg.
Sometimes this returns a section of HTML with āBad Gatewayā, and then generates an āUnable to parse JSONā error message in the logs. Any way to catch this ?
Well the preferred way to access is attributes is state_attr(sensor,attr) so depending on what results would normally contain, then I would be looking at something like testing
That wonāt work as well as you might think it will. If state_attr fails to get the value of results, the value it does return isnāt a list but the template will attempt to get the zeroth item from it (and cause an error).
I donāt know of anything in the RESTful Sensor that allows you to perform error handling (i.e. validate the received data and handle errors gracefully). However the Command Line Sensor lets you invoke any external command so, instead of using curl, you could call a python script to perform the task. Python provides you with all the flexibility needed to process the data and handle errors. However, if you donāt know how to program in python then that might be a significant hurdle.
Iām having a similar problem. first, let me try to explain the situation. Iām trying to determine if the current time is āin rangeā of variables for each day of the week. To try and simplify things for discussion (it took me hours to create this post ) letās assume we are looking at the entities only for Sunday. The input_datetime entities the user sets has no date component. e.g.
Template warning: 'timestamp_custom' got invalid input '00:00' when compiling template '{% set days = ["sun", "mon", "tue", "wed", "thu", "fri", "sat"] %}
time: "{{ '00:00' | timestamp_custom('%H:%M') }}"' but no default was specified.
