Hi All
I am really bad at templates and normally always manage to put together what I need even if its long winded. Over the years I have created template binary sensors for example to show on/off OR true/false for a group of devices (normally in the same domain) like all external doors for example and then I can easily use this in automation and scripts as a condition.
However as I grow with HA so do the number of devices and entities etc and I wonder if someone can help explain how I could be a little more intelligent by using templates directly in the automation or script as a condition.
For example something I want to do at present is have a template condition that is only true if all timers are not active (idle). Would someone be so kind as to show an example on how I can make this type of template without having to make a sensor like I normally would as in this use case I am highly likely to add more timers and I guess by learning the correct templating I can avoid having to remember to add any new timers to my template binary sensor moving forward.
Thanks in advance
