Hello, I’ve created an automation to turn a sonoff wall switch into a cover switch.
Since I have several shutters I created a blueprint. Everything works ok with the exception of the template conditions. In the original automation the template conditions works ok, but when I put it in the blueprint this conditions are not assumed.
This is the code of the automation were it works ok:
- if:
- condition: trigger
- condition: template
value_template: "{{ (state_attr('cover.persiana_wc', 'current_position')|int) == 100 }}"
then:
- service: cover.stop_cover
data: {}
entity_id: cover.persiana_wc
This is the code of the blueprint (where this condition is ignored):
- if:
value_template: "{{ (state_attr('!input cover_persiana', 'current_position')|int) == 100 }}"
then:
data: {}
entity_id: !input cover_persiana
I would like to have this condition working in the blueprint. Does anyone has a sugestion?
