I’m trying to create template switch but i’m getting error.
Confg:
switch:
switches:
television:
value_template: "{{ is_state('switch.plug_158d00039bb63c.attributes.load_power'|int > 50) }}"
turn_on:
service: switch.turn_on
entity_id: switch.tv
turn_off:
service: switch.turn_off
icon_template: >-
{% if is_state('switch.plug_158d00039bb63c.attributes.load_power'|int > 50) %}
mdi:television
{% else %}
mdi:television-off
{% endif %}
Error:
Szczegóły loga (ERROR)
Logger: homeassistant.helpers.entity
Source: helpers/template.py:1016
First occurred: 10:33:50 (1 occurrences)
Last logged: 10:33:50
Update for switch.television fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 279, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 470, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/template/switch.py", line 195, in async_update
state = self._template.async_render().lower()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 228, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.7/site-packages/jinja2/sandbox.py", line 462, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1016, in wrapper
return func(hass, *args[1:], **kwargs)
TypeError: is_state() missing 1 required positional argument: 'state'
