i tried to add new templates for calculating and comparing humidity to be able to control the ventilation. copied the code from Simon42.
now I got errors and according to home-assistant template website I found out that the writing changed and there is an old and a new way.
before that it worked, when I add the new code i get an error. the strange thing is the new code works, when I remove my existing templates. and vice versa.
I would like to update my config to the new standard, but don’t know how. here is what I got:
template:
- sensors:
- name: "Anruf-Status"
unique_id: 'phone_line_status'
value_template: >-
{% if is_state("sensor.fritz_box_7590_call_monitor_telefonbuch", "idle") %}
Leitung frei
{% elif is_state("sensor.fritz_box_7590_call_monitor_telefonbuch", "dialing") %}
{{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.to_name }} ({{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.to }})
{% elif is_state("sensor.fritz_box_7590_call_monitor_telefonbuch", "ringing") %}
{{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.from_name }} ({{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.from }})
{% else %}
{{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.with_name }} ({{ states.sensor.fritz_box_7590_call_monitor_telefonbuch.attributes.with }})
{% endif %}
icon_template: >-
mdi:phone-classic
mdi:phone-outgoing
mdi:phone-incoming
{% else %}
mdi:phone-in-talk
{% endif %}
- name: "weather_home_humidity"
value_template: "{{ state_attr('weather.wetterdienst', 'humidity') }}"
friendly_name: 'Außen Luftfeuchtigkeit'
unique_id: "OutdoorHumidity"
unit_of_measurement: '%'
# Errechnet aus der relativen Luftfeuchtigkeit und Temperatur im Innenraum die absolute Luftfreuchtigkeit in Gramm pro Kubikmeter
- name: "Absolute Luftfeuchtigkeit Holodeck"
unique_id: "AbsoluteHumidityHolodeck"
unit_of_measurement: "g/m^3"
state_class: "measurement"
state: >
{{ ( 1000*e**(19.016-(4064.95/(float(states('sensor.innen_temperatur'))+236.25)))*100/(461.66*(float(states('sensor.innen_temperatur'))+273.15)) * float(states('sensor.innen_humidity'))/100 | float) | round (2) }}
# Errechnet aus der relativen Luftfeuchtigkeit und Temperatur außen die absolute Luftfreuchtigkeit in Gramm pro Kubikmeter
- name: "Absolute Luftfeuchtigkeit außen"
unique_id: "AbsoluteHumidityOutside"
state: >
{{ ( 1000*e**(19.016-(4064.95/(float(states('sensor.hue_outdoor_motion_sensor_1_temperature_2'))+236.25)))*100/(461.66*(float(states('sensor.hue_outdoor_motion_sensor_1_temperature_2'))+273.15)) * float(states('sensor.weather_home_humidity'))/100 | float) | round (2) }}
# Errechnet den Untschied der Luftfeuchte von innen und außen in Gramm pro Kubikmeter
- name: "Absolute Luftfeuchtigkeit Unterschied"
unique_id: "AbsoluteHumidityDifference"
state: >
{{ ( float(states('sensor.absolute_luftfeuchtigkeit_holodeck')) - float(states('sensor.absolute_luftfeuchtigkeit_aussen')) ) | float | round (2) }}
- binary_sensor:
- platform: ping
host: 192.168.1.200
sensors:
desktop_online:
friendly_name: "Mein Computer ist Online"
delay_off:
minutes: 1
value_template: >-
{{ states('binary_sensor.mycomputer')}}
the error says
Error loading /config/configuration.yaml: while parsing a block mapping
in "/config/configuration.yaml", line 70, column 5
expected <block end>, but found '-'
in "/config/configuration.yaml", line 94, column 5
I googled and tests now for 2 hours and I am confused. can’t bring it be work.
hope you can help me out.
TurboKanne
