Hi, i have a big issue. I want put out a text over My script to Alexa. This works fine. I set a variable title and message and in the script i give out to Alexa.
Now is want set a variables called silent. So Alexa script give not out the text to Alexa.
This is My automation.
service: script.test_notification
variables:
title: Türglocke
message: Es hat geklingelt.
image: /api/camera_proxy/camera.haustur_low
silent: true
Ok, I see. I missed that you weren’t using the indirect method to call the script… in the future please format your code properly, it makes it a lot easier on us.
I’m pretty sure it’s just a string-boolean comparison issue. If you are passing your variables as the object variables, then either of the following should work:
{{ not variables.a }}
{{ variables.a != True }}
If they don’t, please post the full automation, script, and any debug traces.
every suggestion has not worked. I think the problem is with the variable. I create a variable names silent in the automation. This calls a script which sends a text message and outputs a voice message to Alexa. However, I would like to prevent some voice messages. Therefore I create the variable silent and want to pass in the case distinction Alexa only the text, which must be spoken. But somehow the variable does not arrive. I don’t really understand this, the title and the message arrive correctly.
