Hi there, I have been trying recently to add a Modbus power meter reader into HA.
But some of the sensors receive the value in ASCII for example } which needs to be converted to decimal 1 125 that represents the real value.
Is it possible to convert from ASCII to Decimal with a Template?
Best results we could archive was using {{ value_json.encode('ascii') }} which converts the result into b'\x01}' but is not the correct.
Any help would be highly appreciated. thanks in advance!
{% set vals="\x00\x01\x02\x03\x04\x05\x06\x07\x08\x09\x0a\x0b" %}
{{ vals.index('\x05') }} <-- example, returns 5
Obviously, continue the control characters up to \x1f and then through the ASCII characters as far as you need. A bit messy and longwinded, but itāll work.
What is that arrow? The ā}ā character is ASCII 125, so if you do a |replace to remove the arrow and then use my lookup suggestion above, youāll get the answer you want. Hereās the full version running out to ASCII 127:
{% set vals = "\x00\x01\x02\x03\x04\x05\x06\x07\x08\t\n\x0b\x0c\r\x0e\x0f\x10\x11\x12\x13\x14\x15\x16\x17\x18\x19\x1a\x1b\x1c\x1d\x1e\x1f !\"#$%&\'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_`abcdefghijklmnopqrstuvwxyz{|}~\x7f" %}
{{ vals.index("}") }}
I cannot remove the arrow as is part of the value it represents 01 in Hex, convert hex 017d to ascii here Hex to Ascii (String) Converter to see the arrow.
