I’ve created a template sensor for my garage door (shutter), as there are multiple ways to open it so I needed a separate position sensor to get the correct position. It works well, except in two situations: (1) sensor battery is dead, so no position updates and (2) door is stopped partly open.
The problem I’m finding, is that in (1), the sensor’s last state is ‘closed’, so the UI widget disables the ‘close’ button and I cannot close the door even if in reality, it’s been opened by another control. In (2), I can’t fully open a part-open door without first closing it because the UI widget thinks it’s already open.
Can anyone suggest a way to make that UI widget keep both the open and close buttons enabled always?
And if you like the way that control looks I have a whole suite of plugins at the same github repo that control different types of entities so you can keep pretty much the whole front end controls similar and have a consistent themeing to the buttons.
Did you ever find a way to keep both open and close buttons ‘on’? I have just come across exactly the same issue as you after fitting a new garage door with 3 buttons instead of the old one with just one button. I kind believe what a complete pain it is.
I have a blind control hardware, modified with a sonoff (eWeLink) smart 3 gang DC relay (open, close, stop) using inching of 0.5secs to simulate a human button press.
Unfortunately have not yet incorporated any sensors to understand state or position.
And configured a cover template for it.
I found that a cover.template defined in configuration.yaml. without a value_template or position_template defined, will default to optimistic: true in calculating the state and position of the cover.
This means it may hold a state of open or closed (position 100 or 0) even when it was stopped or interrupted or otherwise doesn’t really know for sure that’s the case.
The state of the cover (in my case a blind) is then: Unknown
This means the buttons in the UI for the cover are always available.
It looks like some clever folks have developed some timed covers in HACS i might try calculate position and state while also leaving buttons available. Or probably better to use some reed switch sensors to determine position. But for me this is more a ‘nice to have’. I just want to be able to control my blinds!
