Hello. I have made a sensor that keeps track of the last time my cat has eaten based on certain factors around my house. Works splendidly. The question I have is how do I get it to ignore Home Assistant restarts when I use last_changed or last_updated? This template works great until restart of HA or reload of template entities. Then they show the time I restarted or reloaded.
So because the automation that causes the input_datetime to update relies on a template entity as well, this will not work, because every time I restart HA, it triggers that automation…
Whether it works or not will depend on whether Home Assistant will allow your automation to reliably update the input_datetime just moments before it shuts down.
As for your existing trigger that monitors the sensor’s last_changed value, you’ll need to add a time constraint that prevents it from updating the input_datetime if Home Assistant started just seconds earlier (because that’s when it forces the sensor’s last_changed to the current time). The Uptime integration is useful for determining how much time has elapsed since startup.
@123 thank you for getting my mind thinking again. I was in the process of trying to incorporate the Uptime integration, which is a great idea, when I realized, um… triggers…
- trigger: ##Pants Last Ate##
value_template: >
{{ states.binary_sensor.pants_eating.state == 'on' }}
- name: Pants Last Ate
state: >
{{ states.binary_sensor.pants_eating.last_changed }}
