Invalid config for [sensor.template]: [delay_off] is an invalid option for [sensor.template]. Check: sensor.template->sensors->motion_delay_corridor->delay_off. (See ?, line ?). Please check the docs at https://home-assistant.io/integrations/template/
I even tried to copy/paste the template from the integration page and get the same error I tried to write the whole think by hand in case it was a special character when I copy/paste but nothing works.
Please could you clarify?
I can’t declare a sensor in configuration.yaml since Hass says there is a double mapping because of “sensor: !include sensor.yaml”. Have you put all of your sensor entries back in configuration.yaml??
